Lol had to cut and paste the rest to see wtf it said, GG.
While this device has proven itself to be able to create a weld from the review, it’s a long way from being a spot welder anyone here should consider.
This is best suited to making small 5V battery backup assemblies or other small electronics.
What differentiates it most from the main spot welder options is it’s thermal management. Batteries, cables, connectors and PCB components get HOT during spot welding. That’s where this device will fail
Consider this, a 21700b 12S5p pack I did some work on a few months ago had three layers of 0.2x10 nickel strip per series connection. The first spanned all 10 cells, the second layer 8 cells, the third layer 4-6. Thats 3 welds per cell x 24 weld locations per series connection x12 series connections. That’s 864 welds- and I had nickel on top of the P groups already. So add another 60x3 more.
Even with a KWeld, maelectrics etc, you have to stop frequently and let the device, cables and lipos cool down.
Maybe we could make an argument it has a place for repairs, but battery repair happens very infrequently and it usually requires opening a good portion of the battery.
This device won’t be good for building a pack. We also don’t know much about thicker nickel in the 0.2-0.3 range, nor do we know how it performs through 2 layers of nickel. It’s max rated to 0.15 nickel, again not a good start.
I mean, it runs at 5V off a single 18650. My maelectrics has two 3S 120C 5Ah lipos in parallel. There’s also quite a bit of discussion around battery chemistry selection for spot welding and liion is typically not the choice.
Given its size, components and cooling its functionally not possible for it not to suffer from thermal issues with repeated welds. Given that the battery, terminals and PCB are all on top of each other, this problems gonna be really bad.
Small diy work maybe. Building a battery, even a small one- I would strongly recommend against it
So it can do .2 pure nickel slotted if you are using the capacitors. It can do .2 non slotted if using a lipo or car battery. So 40.00 + lipo for non slotted is not bad for an entry level welder.
we can get started without him.
can someone print a soft protective cover for this? Preferably one out of material that reduces friction?
I’ll try this nanospot thingy if they make it past kickstarter and into production. At the moment i have two Sunkko 7xx series units in a drawer, a sunstone cd150dpm on my bench as my daily welder and a K-Weld kit on the way. I’m always interested in battery welders though. Its one of my most used tools.
A very special hell filled with fleshlights and no penises. Not even yours.
All I can say is i ordered two red rockets
if it looks like penis… and quacks like penis…
Must be a kook?
indubitably
if you are doing ONE… battery granted… and wish to forgive the proclivities… buy it…
i won’t hate you… but all your responses make it seem like you’re trying to convince yourself…
WTF… it’s your bux… spend them as unwisely as you choose… no fukks given…
