Long axis , easy job
Why is this?
As we’ve thoroughly explained above, short axles suck balls for esk8 use.
Lol, ok
Basically it would be moving back in time, back to the 2016 methods
There is nothing innovative about 35mm or 37mm axles and I personally would not buy them under any circumstances.
“You can lead a horse to water, but you cannot force it to drink”
Just use a shoulder bolt, they are great
What’s the biggest motors you could run on these?
H ehates spacers I guez
Apparently hates selling stuff
I was actually gonna put unlimited NEO hubs on these…
So I am one of the few people who would be ok with too short of axles for pulleys.
When are they going to be ready I’m Interested in a set
They are in presale ! Expected to ship in mid-April.
Biggest motors it can fit?
200mm is only suitable for 2 6354 motors
would using the BN geardrives allow for bigger ones?
I don’t believe it. This is dual 6355 on a 177mm SR TKP hanger:
I could definitely fit dual 6364 and I may even be able to just fit 6374 though that would be really tight.
With 23 extra mm, you shouldn’t have any problem fitting 6380.
You have to make the axles longer though! Or at least make the hanger compatible with the BN axles.
Might as well ignore this whole product, they’ve indicated that they will not entertain this idea.
You’re still trying to lead the horse to water when it’s already demonstrated that it will not drink
I’ll make it easy for you to understand what people are asking for. People like to speak in code here instead of saying straight up what they want . Though you should research the other vendor offerings when developing a product. Extended axels, at least 50mm+ in length, to install press fit hardware. You’ll sell more here that way. Good luck.
