Wow trampa customer service are , just got email that they will sent me spokes replacement, hope they are better time, really want to rideāem.
Can confirm the fitment on MBS however you will get a more rounded tire profile at the recommended psi. I would go for MBS, mainly because theyāre like $15 a hub and are actually really nice.
Nice, have you try them? Is there any wobble noticeable on mbs?
Yeah, they are great. Its a great way to get 6in wheels on trucks with 12mm axles.
What spacer you use, on which axle you are planning to use
What about the spacer, i saw no spacer on mbs website, use no spacer or custom one?
MBS doesnāt recommend spacers. They have told me that the spacer only prevents over tightening. That makes sense, but I prefer to use them. Bearing spacers for MBS Rockstar 2ās are typically 22.5mm wide assuming standard bearings. You can get them here.
The most fool proof method is listed below, this is a direct quote from @MBS.
The best option is to measure your bearing to bearing distance on your specific hubs, then subtract 15.8mm. For instance, if bearing to bearing distance is 38.3mm the spacer would be 38.3-15.8=22.5mm.
I just say this because the bearing to bearing distance differs slightly on different models of hubs (nylons vs. alums), this makes sure you donāt get a rattling spacer, but also donāt end up with your bearings sticking out of your hub.
Lacroix also has axle spacers.
Thanks mike, great infos always. Iāll use 10mm axle, maybe lacroix bearing spacer is for 12mm axle. But i can always make custom one, no problem.
Are the bearing is press fitted on mbs like on urethene? Also do you know if the bolts position is same with superstar (to use same pulley)
No worries, happy to help.
Yeah, the Laxroix spacers are for 12mm axles. You will have to make them or you can buy what you need from aluminumspacers.com.
If by press fit, do you mean are the installed the same as on thane, then yes. My standard process is as followsā¦
- put the hubs together
- set the 1st bearing place, use the arbor press to seat the bearing
- flip the hub over, set the spacer in place
- set the 2nd bearing in place, use the arbor press to seat the bearing
I dont have any in front of me to measure, but I am pretty sure the bolt patters for trampa hubs and MBS Rockstar 2ās are different. If I remember correctly, when I was testing out a bunch of nummie hubs, I had to wait for an order of pulleys because the trampas wouldnāt fit the MBS hubs.
@moon mentioned that MBS and Superstars have different bolt positions. Meaning yeah youll need new pulleys. I think MBS sells them though dont they?
Pulleys sold out at the moment
Ok noted, thank you
Nice, I didnāt know evolve got this, thanks
Yeah, Evolve Germany are a distributor for this MBS pulley, which is funny because the MBS EU distributor in the UK doesnāt stock it, only MBS in the US sales it.
FS has a whole setup with aluminum hubs and pulleys I havenāt seen before.
I think that is same, sunmate alloy hubs
THIS
is eggzakkery how i deal with itā¦ i tighten axle nut to first resistance and back-off 1/8th of an RCHā¦
