Oh that isn’t this wheel pulley?
no def not. pretty sure it’s this one https://trampaboards.com/12fifties-carbon-fibre-motormount-panel-with-custom-motor--pulley-kit-for-stickies-longboard-wheels-twin-p-26963.html
Oh wow, that almost looks like the same or a very similar pulley
Is it 36T 23mm wide? (“22mm” size)
not sure how wide exactly but it’s it’s 32t
do you mean 33t?
trampa doesn’t do 32t for this application
yeah just checked 33t mb
Confirmed it was the battery regen current that was the issue. Apparently -6a is too high and -12a (per side) is ideal, I might go a little higher and mess with throttle curves later to get in the perfect smoothness.
Why 40% (and not 10% or 50% for example)?
Honestly, good question…I personally think it’s a safe current for the batteries to charge. It only directly affects the braking power at high speeds
