Thats a fair point. Though if he is having them put a custom connector on it, it might as well be a JST PH 2.0mm 7pin, and then folks can rearrange the pins as needed, or do your solution of just de-pinning the connector and using the crimped ends on their own.
Most HW6 VESC’s I have seen have VCC, GND, and ADC1 on the same 7 or 8 pin JST. I dont think we can get a solution that will work perfectly for every VESC, but JST is nice in that its easy to re-arrange and make work for whatever is needed.
I have so many cells I need to get rid of so will sell this potted batter yes. Fits a 35.5 downtube on a Lot of bmx bikes frames. This one being the cheapest.
And have custom torque arm adapters to fit motor into the standard 14mmdropout. @iamasalmon but more so looking forward to the 24” bmx frame with the 20” wheel in it so can accelerate quicker without flipping. That was the last bike’s issue.
They have one model they say is custom and this is it. This one alone I think is two direction. 170x model.
I’ll do the group buy here and change the title when it’s confirmed that three pin/wire is fine for the vesc. It is right?
And a single plug? I guess u could move the pins around but rather it be good to go for the vesc6
@hummieee If the throttle unit has 3 wires, then it is going to be plugged into GND, ADC1, and either 5V or 3V or VCC. I really dont think there is one solution that is going to work for every single VESC, or every single person’s application for it.
In the interest of simplicity, I think the best connector to order is one 7 pin JST PH 2.0mm connector. The wires can be populated into any slot because most people are going to have to re-arrange them for their specific VESC anyway.
Basically what im saying is that if you get a 7pin connector, then the wires can be re-arranged inside the connector to line up with the correct pins on everyone’s VESC’s. Some COMM ports are only 7pin, so dont get 8 pin. If you were to only get a 3 pin, and one of the needed pins was two away from one of the other needed pins, then one of the wires would be outside the housing. 7 pin is the best compromise that I can see.
You call my word vomit ramble “coherent”? Thank you, Im glad that it got my point across. It could probably have been accomplished in a few hundred fewer words lol
This is why i should not be allowed on the forum on my computer. Having an actual keyboard means I can type as fast as I can think, vs on a phone I have to actually consider what I want to take the time to write lol
