Will probably assemble everything on friday or saturday
Some good and cheap grease.
Thanks! Already got this however
The bottle openerâs pinions are a bit sharp. But that guy is on my keychain with my other keys.
The assembling doesnât take that long.
an hour max.
No time tonight
Doesnât matter. Itâs going to take a long time anyway with two right gear drives.
Youâd finish installing one and then be thinking, wait a minute, didnât I just install this one? Whereâs the left one?
Thoughts on the mesh like this? @NoWind @rich @Andy87 @taz @Mainflow. Not sure if I got the backlash on point.
Looks good.
Do you have a keyway?
No doubt, the backlash is too much. You want as less backlash as possible. The best way is to mount a hub (or just slide it on the axle with hub adabter) and tighten the axle nut so the wheel gear is 100% true. Usually I insert all 4 motor bolts but keep the 2 below the gear loose (slideable). Then I go to the point where no backlash is and barely slide the motor away and tighten the 2 bolts. Afterwards I check the backlash all around. Sometimes itâs first try, sometimes it need 3 times, never did it with the âpaper trickâ but the wheel gear should just wiggle a bit everywhere, thatâs it.
From your pic I would say you could go down about to the red line.
With too much backlash you decrease the durability and strength of the wheel gear. Also with more backlash than on your pic the tips could break e.g. when jumping. I really abuse my gears and there is zero damage, I climb hills where I thought first I gonna crush the gears (and not possible with belts). Also jumping is no problem. As long as the backlash is not too much you canât kill the gears.
Edit: Unfotunately many hubs wobble a bit which can affect the backlash. So in a perfect world you adjust the backlash with the same hub which you gonna use later (with tightened axle nut). But you have to remove the tire to be able to tighten the motor bolts.
Yes its an 8mm key
Thanks Rich! I will take my time and adjust it
Like @rich said I would get a bit closer with the gears. What helped me a lot was watching @NoWind video
https://youtu.be/o9ZGqqfG0C4
Just pay attention to the sound and amount of backlash when he wiggle the hub after assembly.
Too much backlash !!!
Thanks andy and rich.
Cleaned the gears because I thought the backlash was okay at first and already greased them yesterday oh well live and learn, im glad I asked you guys to make sure. Working on getting it done right
Nice!
I see you have managed to work that right into a left.
Magic
I think, youâre done?
