@torqueboards Will a 30" dual gear drive 6380 TB be able to climb hills? Or just the 30 like what is the diff
Climb mountains. lol. I doubt youāll need any of that. 2WD Gear Drive 6355 uphill on a 30". You wonāt have any issues. @Underoath888
That would be a comically wide 30 inch deck setup.
Where can I buy the 30"?
Ok well then dual 74s I guess I do have hills to climb lol.
What is your weight?
Even that seems really wide for a 30inche deck om geardrives
@Skunk @BillGordon @torqueboards Here are thills Iām speaking of just figured Iād need a 74 at least . I weigh 145 lbsIMG_20191007_083856|375x500
Just going to leave this here
@Underoath888 Yeah, thatās nothing. Youāll be surprised.
Perfect example of a shortboard dual gear drive.
If I ever upgrade my spud in the future, Iāll probably do dual 6355s. Any bigger than that, itll be a bit too wide and heavy for my taste
I understand . But even a belt drive on 12mm belts is gonna be awkward with dual 6374 motors on a 30 inch deck, and geardrives take up more space.
I donāt even like Ecaliber trucks on my 30inch deck.
6364 is the biggest I would go on a short deck and thatās even kinda wide.
Thatās a super beneficial weight. Properly fed 6355 dual setup will be plenty.
I think Iām gonna buy a 30 and 40 inch deck and then just swap the motors and battery compartment depending where I go.
All with drop bolts.
The only problem with that is I would do a considerably different configuration for my battery between a short and long deck
Considering you were planning for a four-wheel drive build.
I bet you could get away with a good two wheel drive longboard, and a respectable single Drive shortboard for probably less than the four-wheel-drive build would have cost.
Single drive short boards are super fun @Underoath888
Great for portability and just general riding.
Im 150lb and I ride a 170kv single 6374 on some steep hills with no problems.
I think Iāll dual motors for both and just swap Wheels and Decks as needed.
12S4P and dual 6374s til I can upgrade to a bigger battery and 2 more motors
Dual 6355 is just as fun just saying?
You dont need anything more then that.
@yelnats8j need the prrrroooooofffff lol
Can I go 20 Miles and 30 mph like the 74 can?
