This is some impressive design and fabrication.
I’m curious if there is enough caster in the steering to be stable. I guess you’ll find out!
Thank you!
I really don’t know how it’s going to handle. I may have to change the steering geometry. I’m already making changes to the design for version 2.0 based off things I’ve learned so far.
Brandon
Parts are starting to roll in for the drive system. I’m excited to take my first shot at battery building.
Brandon
So, it’s been a while since I’ve given an update. What can i say, life gets in the way. Anyway, I wanted to do a stability test before installing battery and motor. It seems controllable at slow speed and gets more stable as speed increases. My daughter (crash test dummy) only had 15 minutes experience on it when we took this video. Hopefully now i can move on to final assembly.
Brandon
Impressive,more so you get to share with your daughter
