let me get back to you if the enclosure height and width is enough
acc datasheet has 50G 15A peak, that means 270A from battery. Actually each motor has 5600W power, so i need 220A max from battery (full torgue is just for few seconds, from 0 to 70kmh is about 5sec max)
how do you get that?
5.6 x 4 = 22.4 kw
14 x 3.7 = 51.8
22400 /51.8 = 432 amps max to get the full torque
eitherway you will prob get insane torque from it
good luck
Good job! I love seeing the “process” photos.
Yeah, but you have to know BATTERY current vs. MOTOR PHASE current issue, its not the same. Each motor has 5600W that means 5600W/51,8V=108A motor phase current, you know each motor has 3 phases, that means 108A/3=36A of battery current. That explanation is very simply, sinus curves of each phases are little covered by them selves and so on. So I use 50A for motor, 200A totaly, 220A from battery with some issue…
