easy to get in hex cap, and I can carry just metric tools for everything
Do you ever use chambered/recessed/flat head (depending on what they call them in your part of the country)?
Thats what I am seeing too, 1mm stamped are everywhere. A precision and/or .5mm are unicorns.
not much, though those are useful for enclosures when using fender washers
Iām in for a mondo kit, anyone who has seen my workspace during build or repair time itās a mess with boxes of screws everywhere Maybe include some m4 1mm thick washers, they came in handy for my latest build when I
Was having motor problems.
I will look into them. Thanks
Iāve got like 100x of them sitting around, very helpful for if you are tightening you motor to the mount and the motors resistance gets tighter the more you tighten. Throw some in between motor and motor plate and your motor is āfixedā! Iām in for a Mondo kit thatās for sure!
I have some, not sure where I got them though . Ill look around and see what I can find.
Consider shipping to your Canadian cousin!
when you forget the serious tag on your esk8.news thread
and you put the word āNutsā in the title
If I use a 9 mm spacer in my Six Shooters I can bind the bearings and if I use a 10mm spacer I get a click. A 9 mm with a 0.5 mm shim stacks perfectly.
I have 10mm speed rings that are wafer-thin but finding those for 8mm axles was very difficult without ordering a million of them.
I bought shims here. Price isnāt bad. The problem is the 10 mm ID shims I got donāt quite fit over my 10 mm shoulder bolts. It is an easy rework but annoying. I havenāt put much thought into whether 12 mm would work okay.
Tolerance for ID is apparently +/- 0.3mm
OD has tighter tolerances for some reason
I got some 8mm shims there that donāt quite fit over my axles
Iām happy to ship to Canada but itās gonna be pricey. PM me an address and Iāll get a quote.
I never do serious threads, the anarchy speaks to me
Iāll not be asking to have those printed, thank you anyways
Maybe some 3mm keys? Since they are so cheap in bulk and everyone needs them
