duty_cycle control vs current_control
It is Mxlemming’s vesc guide .Basically for responsiveness there are two things you need to tune, the current control pid(or pi) and the observer gain if you are running ortega original.
You can do a test, if you put a very high time constant on the master controller and a low time constant on the slave. And push the throttle, the difference is clear.
