So it’s raining in Seattle - we had a lovely week or two earlier in the month but now the rain is back which means all the activities I had planned (esk8ing mostly but a bit of bicycling) got cancelled and that means time to work on the Runner!
Both transmissions complete, broken in greased and ready to roll:
Now because I’m using aluminum extrusion as the frame for my board I need to make 2@ 21 degree truck mounts. I’ve made these before, but I screwed up the first one this time around (I had an embarrassing hack of a holding system for the mill involving an angled piece of plastic, It was really janky and the piece jumped out of the vice in mid cut) I decided to do the right thing and mount them properly this time and rotate the vice 21 degrees instead of trying to mount the part 21 degrees into the straight vice. This is what I came up with
And here are the finished pieces
The slots allow me to embed the mount into the extrusion (there’ll be a picture of this later and you’ll see what I mean)
Here’s a picture of my daily driver esk8 so you can kind of see how it all goes together:
So I just happened to have a frame from an old thane build that I scrapped so I went ahead and started mounting stuff to it just to see how it would fit. That’s when I noticed my mistake.
so far so good…
Now that’s looking downright sexy.
You can’t see it in the picture, but the truck is backwards. I didn’t consider when I was modelling the profile that the truck had a front and a back (which it really doesn’t except for the logo and the bolt head/tail) and I had a 50/50 chance of getting it right, which means, inevitably, I got it wrong.
But I don’t think I really care. Obviously the truck is linear so functionally it makes no difference and I can mount the front truck correctly (the one people will see) so I’m letting this go.
Next steps:
I need to make a decision on the tires - do I continue to wait for the other two plastic wheels to arrive or do I bite the bullet and start designing/3D printing hubs for the rubber tires. I’m leaning towards rubber.
the old frame in the above pictures isn’t long enough. I need for the rails that form the deck to be at least 37" and those in the picture are probably closer to 29 or 30, so a Misumi order is up soon.
I’m debating on the deck. I was going to make a bamboo and walnut deck, but unfortunately I found an old maple ply deck that’s pretty close to the correct length and already shaped and ready to go, so despite the fact that the bamboo deck would be a work of art, practicality dictates that I use the one I have. I can always swap it out later.
Lastly I decided not to get the Maytech motors because despite what they say they are clearly not IP54, as evidenced by this still I grabbed off the advertising video:
you can see the coils between the can and the face, which means sand would get in there and destroy it in a matter of minutes.
