Lets leave a side for a moment my drawing and use the XT90S as the reference.
Lets assume Im half plugging it so the circuit is closed with resistor in series… (For a long time)
Resistor of ~5ohm in series with capacitor
At initial moment, capacitor’s resistance (impedance) is zero, so total resistance is 5 ohm, so lets assume we have 40v, thats 8amps flowing…
Moment later, capacitors are loaded, so current is less than 8amp…
It starts with 8A and goes down to 0A in a charging time of 5tau where tau is RC so 5ohm times 220uF times 5tau, we get total charging time of ~5ms
apologies, you need a SPTT (single pole triple throw). So basically any point on the switch connects the input to your selected throw.
This means one input and 3 selectable outputs. Output 1 is to nothing, being off. Output 2 is through your resistor, and output 3 is straight to the load.
I honestly think this would work as long as there’s no load on the resistor. I don’t see it being any different functionally as an XT90S. As long as you do like a quick flick past the resistor straight to the output 3,it should be enough to precharge the capacitors (correct me if I’m wrong @b264@kook )
Because if the fuse blows, you will have a mighty spark destroying other things. Also antispark are kinda designed to take huge, albeit extremely brief, amounts of current
If that fuse blows then the switch will probably weld closed next time you try to use it
Agree with all this, but you’d have to experiment also. Add about 10 millifarads and try it on that, I think most ESCs have about 1 - 2 mf per motor so if it works with 10 then it should be golden
