you’re ignoring that momentum is also gained equally… during the first portion of cogging, the motor slows down, during the second part it speeds up without any outside force. result? net 0 loss.
that’s entirely separate from the overall conversion of momentum to heat which is an entirely separate phenomenon unrelated to the cogging.
And I’m saying to u the only difference between a cogging and non cogging motor is slots. So ur copper pipe…we now have a copper pipe w slots… which gunna fall faster slots or no slots?
How u gunna have eddies that form an exponential line …now it has some freak loss at low speed, that is also superimposed on the motor torque continuously at any rpm. It has its own torque curve that’s mappable.
@hummieee you seem unable to mentally separate two discreet phenomenon…
one effect causes the wheel to speed up and slow down while retaining all the original energy (cogging)… no net momentum loss
the other effect slows down the wheel by converting the kinetic energy to molecular vibration (heat)… which converts the spinning motion to vibration, thence to infrared photon energy…
removing the first effect has no effect on the overall efficiency or the second effect.
^i simply place the motor at the potential peak and let go and it spontaneously accelerates… until conversion of kinetic energy to eddy currents, to heat, to infrared radiation causes the motor to stop
You’re again proving my point that cogging is not the source of the resistance, but eddy current. A pipe with slots will have less eddy current and thus the magnet falls faster but cogs.
