Direct Drive BoundMotor Kit (Elofty Style)
You should probably read through this thread a bit. No one really knows weather or not they’re the same as the og elofty’s, there are some clear difference’s between the bound first drives and lofty’s like the set screws on the cans. These new ones are a bit different, I’m wondering if they changed anything with the axle’s or else wise on the new version.
I’d also probably consider TB110’s for a little more ground clearance than the 100mm boas.
