Yeah, exactly. It’s weird.
Already doing enough diy with the board? Just want to finish the project asap now without anymore headaches?
All spare parts are now available for purchase in the e-shop:
I’m not seeing my p groups displayed. How do I get the Davega to display p groups? Everything else is there.
Do you have a compatible BMS on the same CAN bus as the VESC that your DAVEGA is connected to?
Yup… I have a Flexi Lite. Everything seems to be connected correctly.
CAN is enabled on the Flexi?
Actually, that’s likely the problem… Thanks!
Im not seeing anything regarding enabling can on the flexi?
Try $32=1
No joy. That didn’t work. I just don’t understand what is wrong?
On the can cable, I only connected can H and can L. Could that be the issue?
Did the bms boot up?
Yup
I’m not seeing any lights on the BMS when I turn the unity switch on…
Connected the opto enable. Works now. Thanks!
Hm, weird. I don’t think that’s necessary. @SimosMCmuffin, can we please have your input?
I gotta say it was in fact necessary in this case. I thought it was not. That’s why I did not connect it to begin with. I’m not very good with electronics. All I know is connecting the opto enable solved the issue. I saw a pack badly out of balance, so I’ve now set the Flexi to always balance to correct this pack.
FlexiBMS lite is now available to purchase in the DAVEGA e-shop so you can grab one along with a DAVEGA X and save a little bit on the shipping. This may be especially relevant for overseas folk.
The price is slightly higher than in Simo’s e-shop so you if you want the Flexi alone it makes a whole lot more sense to buy from Simo directly.
