DAVEGA X Updates
Firmware v4.09
Most important updates:
  • faster start up
  • LLT Power BMS support (experimental)
CHANGELOG entry:
- caching CAN IDs (faster startup)
- LLT Power BMS support (experimental)
- configurable update interval
- ignore decrease in charged/discharged energy (workaround for a VESC bug)
- fix: updating config from Metr CAN fails when imperial units are used
- fix: time retrieved from Metr CAN does not have correct time zone
This is probably the last v4.x release. v5.01 is ready and all new developments will go into v5.x. The idea is that v5.x will initially have:
  • v5.00 - equivalent to v4.01 + new partitioning
  • v5.01 - equivalent to v4.09 + new partitioning
The v4.01 is the last firmware version that works with the Unity legacy firmware. I’ll provide the v5.00 equivalent so that customers who receive a new unit with v5.01 pre-installed will have a chance to downgrade to a version that works with the Unity legacy. Downgrading from v5.x back to v4.x over the air won’t be possible.
I’ll get started on the v5 installer. Since it’s fairly simple (very similar to v4 installer), it should be available later on today or tomorrow.
