[Closed] [Global] Flipsky 6374 Motors & 2020 200A Enhanced Antispark
Oh also if anyone wants a pair of MR60 connectors with their motors or 5.5mm bullets free of charge PM me and I’ll add them in.
We went for the expidited shipping, and hopefully we’re shipping out today. It would have been the 15th, but during the epoxying process, the motors anodization wore off so its been re-done.
Here are some pictures sent over
They’ve changed over to a flat bottomed design, which is great for putting them side by side where dual 74mm is close (I think TB218 it can be close if the shaft comes out the back like SK3)
flat bottom to have space for epoxy
Here’s an image of the epoxying process they’re using.
And the best parts, the balancing & epoxying. As you can see in the second image, this might be the most epoxy we’ve ever seen from the factory, the bottom 3/4s of the magnets are almost entirely covered. One of the main issues with DIY battle hardening is balancing can’t really be done, but as this is coming from the factory its also balanced. The cuvature of the magnets has been discussed above, but it will mean the motors are extremely quiet in FOC.
balancing glue
That’s awesome, looking forward, thanks!
i’m ordering one for myself soon
would it be possible to ask for a 170kv model?
@anubis I jumped out cause I was in a rush to get some motors can I jump back in now?
Thnaks
The ones I have are 170kv. Its going to be cheaper to order from me than from flipsky after shipping, unless you get a lot from flipsky shipping is like flat rate $30
i’m not in the group buy
I know, I stock the extra motors from dropouts / making it to a higher quantity for a lower price in my shop, nexusboards.co.uk
As you’re in belgium, I think buying from me instead of flipsky is always cheaper even with loads of stuff
I’m not quite sure yet.
I run 5.5s currently but plan on upgrading to mr60. Not sure when though. Do you have mr60 for sale on regular basis?
Why do you do this on every group buy :japanese_goblin:
drop me a PM i guess
Just remembered your 5 pair assortment deal. If i buy that there shouldn’t be a problem sending it with my motor order, right?
Because my flipsky 6355 broke and I needed in instant replacement
It’s fine though
Yea it won’t effect the weight. You can use the discount code MERGESHIPPING and it takes off all shipping costs
um, noob q…, but will i need the bullets or connectors? on my first build and using the boardnamics 220’s if that helps…
It’s a matter of preference, just need to match what’s soldered on the vesc phase wires. The defaults of the motors look different, so we would need to solder something anyway -but if the vesc happens to already have 5.5mm bullets you could ask for these (if you don’t have any) and avoid soldering on the vesc side.
It depends on what your ESC has, I don’t think any VESC based esc ships with 4mm bullets though so you’ll need something, you can either resolder everything or resolder the motor or esc connector to match each other.
well, i ordered the jedboxes, so basically have no idea what esc ill be using now that ship has sunk. but if ill need them please add them to my order (ill dm you)…thanks
thanks for this, ill get Anubis to add them to my order…thanks
So i can add more stuff from your store and you’ll just combine it with my motors anti spark ?
thats also the reason i never that stuff here in Germany.
6 pairs of mr60 cost me 14€ (got a 5€ebay coupon so only 9ish €)
on your shop i get 10 pairs for roughly 11€
I picked up 50 pairs for $33 on 11.11 :smiley:
