Can you provide the lot number of the suspected faulty DRVs? It’s the number right above “DRV8301”
@alwaysmohawk Did your issues end up connected to (potentially) bad DRVs? Or was that something else? Asking because we’re in the same batch
88ASYCTG4 on mine, same lot number on both the “faulty” ones and the “working” ones, only measured with diode mode on the multimeter because I havent had acces to my power supply.
Ordered May 22nd to add additional info like @stratoglide
yeah not sure. I had one board die almost immediately. but I’m pretty sure that my soldering was deficient.
lot number on one of my drv was 88ASYCTG4, but unfortunately I lost track of whether that was from the board that caught fire (whos DRV i tried to put on the board with the DRV fault codes) or if it was from the fault-code one.
when i put A drv back on I saw some sparking from the DRV pins near C17, but again I messed up and can’t be 100% which is which
sorry.
the fire I’m sure was bad soldering.
All 3 faulty ones are 88ASYCTG4 as well here of the 10 I Recieved 9 are 88ASYCTG4 1 is 89C1VQTG4.
I haven’t tried powering any on so I’m not 100% sure but the multimeter test seems to consistently spot the issue so far.
I ordered may 26th incase this helps track it any better.
oh crap hey, speaking of tombstoning, my R22 on my current board was vertical. I assumed that was due to some issue on my part, but in retrospect it seems unlikely that that happened due to some issue I caused. I thought it had exploded and become vertical, but maybe it arrived that way?
R22 is the pullup resistor for the fault signal from the DRV. Without it, fault detection from the DRV won’t work.
It seems that there’s a correlation between lot 88ASYCTG4 and faulty DRVs. @doomy, @Fungineers, @alwaysmohawk, @stratoglide, @Minimadness, and @Style all have had issues with DRVs from this lot number.
So I’ll be preparing a warning statement about the issue for this thread and the github repo. I’m also working on investigating this particular lot to see if it was flagged as a bad batch from the manufacturer and LCSC/JLCPCB got a hold of it somehow.
For those that were interested, I’ve got a pretty good chunk of the how-to guide up for the controller with LCD display and logger here:
I’ll be adding to it and hopefully “complete” it over the next few days. The plan is for all relevant information to be contained in the first 5 posts of the thread. So I’ll continue to update those posts as I get feedback.
how can I do more rigorous testing? do I need a metr pro? (why are they so expensive?)
It has hands down has the best customer support of any tech product known to man. @rpasichnyk Has done an amazing job, crushing bugs, and adding users feature requests.
Once you get yours you’ll understand it’s money well spent.
The thing is also built like a brick shithouse.
Everything else in your build might fail, but that thing just works.
*I am not sponsored or related to Metr any way, I just love that product.
More testing is always good, but don’t try to beat @shaman claimed specs:
Or else It will blow up! If you have attached a heatsink and also give the heatsink airflow then from my testing experience on 13s and around 2kw of power I could not get it over 45C. It ran so cool, which was my reasoning behind tring to push even more current, which ultimately lead to bunch of dead CFOC2s.
I know nothing of the metr pro, but you can certainly log data from the UART using an arduino or similar.
You can use cheap nrf51822 modules from ebay and the vesc mobile app. When you want to start logging just put a checkmark at “Enable RT Data Logging” think of it as a start stop button. This will put a csv logfile in the VESCMonitor folder. If you want to analyze the logs and look at graphs, copy this file to you PC and open it in vesc tool.
I checked my three FOCers now. They are also with 88ASYCTG4
One of them has the beeping noise and can’t regulate 5V.
The other two seem ok
Just sent JLCPCB a stern email, will post reply’s here. I have ordered new DRV8301’s in the mean time.
Thanks for reporting in! The audible ringing and failure to regulate seems to be the common symptom. Seems at least that particular lot number has a high failure rate. Still not 100% sure if that lot was bad from the factory or if JLCPCB mishandled that lot once they got it or something in between.
DRV8301 chips of lot number 88ASYCTG4 suspected of high failure rate
Several users and participants of the CFOC2 v0.9 have experienced failure from DRV8301 devices of lot number 88ASYCTG4 from JLCPCB’s SMT assembly service. This was originally thought to be inadequate soldering but has since proven to be something more complicated. This particular lot has shown to have a high failure rate though not necessarily always failing. Symptoms exhibited are audible ringing from the inductor close to the DRV (L1), deregulation of the 5V output from the DRV’s buck converter, and subsequent catastrophic failure of anything connected to the 5V rail (CAN transceiver, ESD diode, 3.3V LDO, ect)
@doomy has discovered a test to recognize bad units before powering on. On an unpowered CFOC2, perform a diode test with a multi-meter that has this feature from supply positive to supply ground and then reverse. Results should be close to the chart below
Good
NEG - POS + 2.615
NEG + POS - 0.555
BAD
NEG - POS + >3V
NEG + POS - 0.576
I am attempting to track down this particular lot number all the way to the manufacturer to see if this was a known bad lot that somehow ended up in JLCPCB’s stock. If you have been affected by this occurrence, I encourage you to contact JLCPCB’s customer support and seek a refund for the failed DRV units.
It is very interesting though that this issue manifests pretty much identically to that which is caused by an unconnected/badly connected ground pad (inability to regulate 5v/abnormal diode test measurement).
