pretty much that, and added some markup as well
And hired a full-time “social media influencer” or whatever marketing folks are called nowadays.
You can see the pictures and details in this link. https://www.alibaba.com/product-detail/Land-Snail-930-4-Wheels-Waterproof_1600153087045.html?spm=a2747.manage.0.0.6c7a71d2DknuPq
These are features:
1 Especial snap-on for the motor and wheel, easy assembly and easy replace.
2 Whole sealing hub motor and lock shaft to mount, sand prevention and long service life.
3 NSK waterproof bearing, which are dedicated for heavy load motor and maintenance-free for its lifetime.
4 High efficiency dual BLDC hub motors, 92% maximum efficiency.
5 Depth customized FOC controller, make accelerate and brake to be more smooth and linear.
6 Original Imported Lithium-ion Rechargeable battery, high-rate discharge continuously and steadily.
7 Professionally damping system designed for the common load use, with tension suspension and 50A rubber tires filtering the vibration to protect the feet not be benumbed.
(Riding in different conditions and different roads)
8 The Alloy steel shaft with 0.001mm tolerance, heat treatment, abrasion resistant and corrosion resistant, can bear larger load without bending and fracture.
9 Stable structure Shaped PU make sure the contact area when turning is constant and linear, steering feedback is accurate.
10 CNC Trucks, 0.01mm tolerance, accurate without any play.
11 Unibody carbon fiber, max load is 230KG.
12 SPUA coating, waterproof, antiseptic and wear-resisting.
13 UL approved fast charger, 1.3h charge time.
14Original imported battery with depth customized BMS with 6 protect functions to ensure the safe using.
1 Over-charge
2 Over-discharge
3 Equalization function
4 Over temp protection
5 Short circuit protection
6 Over-current protection
Easy maintenance:
- NSK waterproof bearing, which are dedicated for heavy load motor and maintenance-free for its lifetime.
- The wheel with faster drainage design, can drive normally through the water surface
- The wheel with quick replaceable design, much easier replace.
Baseplate can bear a weight of 65-85kg. Over 85kg, we can increase thickness of the shrapnel.
转向桥 前桥架|690x305
It’s for the riders protection because the board is such a pile of shit.
Huh?
@brotherhobby do you have any relationship with mychubby?
65-85kg spring damping is the best, if it is over, we will increase thickness of the baseplate .
SPUA
i want to ask you , you really know electric skateboard,100%? antiseptic, this is to protect the battery from flammability.If you don’t know what I’m suggesting you can do Google SPUA.
antiseptic, this is to protect the battery from flammability.If you don’t know what I’m suggesting you can do Google SPUA. and you shouldn’t comment when you’re not using it.
Lol
In english, shrapnel = 彈片, 破片杀伤, 榴霰弹
I just build the batteries in a manner that makes them highly unlikely to catch fire. Works for me.
So you are antiseptic. Boom.
@brotherhobby does this board feature AMATA?
How thick will you have to make the base plates to support my 506 pounds?
this thread needs antiseptic.
Oh yeah, we can
Antiseptic
Edit: This thread is the best place to look for reply of 2020 I’ve ever seen
so…whats the answer about truck screw pattern?
if Avenue Trucks was able to support new and old school style, why can’t u when its just a copy product with a different hanger?
SPUA is to protect the battery from flammability
SPUA is a hydrophobic coating material that offers water resistance and anti corrosion properities, how does it prevent battery going boom boom when we zoom zoom?
Side note, funny how SPUA isn’t a widely used material for water resistance or anti corrosion industry outside of china.
