After reading all this I feel a whole lot better about just buying a new charger for ever voltage I got. Which so far is 12s,16s, and 20s. If each charger is around 120 then that’s $360. I’m imagining this system would (at the end) cost more than $360?
What’s the size of the potential market? How many people have this really cool problem lol
Eh, if you were DIYing it all you’d probably need is a 120V adjustable DC power supply and an arduino which would add up to about $120 if you bought a cheap power supply. Messing around with 120V power supplies is not something I really like though as they’re actually dangerous. On both ends and just about everywhere inside assuming you get one capable of any reasonable current.
I have a smart charger that goes up to 12S and if there is no balance cable connected it just asks after detection if the guess S-count is correct, and if not, you can adjust it.
Well yeah, something similar to that. In electric cars they use something called a Control Pilot signal, which is basically a pulsing square wave that encodes what the charging station is cable of delivering. Ex 10% duty cycle = 10amps, etc… They also use switching resistors to drop the voltage of the control pins to indicate the vehicle charging status and whatnot.
My spontaneous idea for low voltage PEVs was to use CAN combined with smart BMS to exchange data, but this is all theory talk.
Naah just a normal charge plug. I like your idea of a physical switch on the charger, it’s precludes the need for any extra proprietary-style connections. Nobody wants proprietary.
