Both sensored and unsensored, canbus and no canbus. Nothing happens, nothing spins.
Running bldc wizard throws these faults and motor spins really stuttery:
Tried all possible combinations. Conversation with frank suggests blown vesc. Damaged shunt amplifier, resistor or drv.
That said, if anyone knows a vesc wizard inside the uk, that can fix this relatively fast (i mean, not sitting on the desk for 1 month)… or at least run some quick diagnostics with me, at cost, i’d be greatful. @Halbj613 yes, got your bluetooth module too. Still sealed, may post tomorrow
Fine to ask here if you can’t find a thread for it (and being new to the forum good place to pop in and say hello), but take a look in the top right for the magnifying lens icon on the site here and can search for “safety” and will find a few good related threads that you can jump in on as well.
Now the good vesc is giving unbalanced currents fault, with new motor, new everything… £500 in parts and i STILL don’t have something that works.
Should have cut losses a long time ago
Try it with some different vesc if you still get the faults then obviously vesc is to blame
If you do get the faults then make sure the battery is good and there are no issues with that
Otherwise it is motors or some other miscellaneous parts
No issues with the battery/antispark/solder joints. Voltage would drop in rt graphs or things would get hot. And i don’t have any other functional vesc besides these two right now.
Best part is i can’t even sell these now, since i know the moment they see a load they throw out fault codes
