Can be done, but itās risky - Thereās a good chance youāll bellmouth the hole (sides not parallel anymore) or accidentally make it not-round or oversize.
If youāve got a set of calipers, or even better a snap gauge and micrometer, then you at least wonāt be working blind.
If I were going to do it, Iād use a bearing scraper rather than abrasives as well, it allows more fine control of where the material is being removed from.
Cheers bro. Iāve hit up MBS so Iām gonna wait to hear back from them before I go any further. Donāt have a need for any more expensive paperweights.
If MBS isnāt helpful, Iād recommend asking around your local machine shop (if youāve got one), itās a pretty simple thing for them to do and shouldnāt be very expensive. Certainly cheaper than a fresh set of wheels.
So without JB weld iām definitely fucked. I put something between the clamp and truck and moved it a bit but it slipped to the previous hole and extended it to a bigger Crater. Guess iām gonna buy a new clamp or new mounts altogether.
Iāll be wiring it in a way that it will have to be on (loop key plugged in) to be able to charge it. Connecting it to the positive wire coming off the loop key (not directly to the battery)
So I am currently in the works of a 2wd powered by TB 6374ās on a gear drive. I am debating making it a 4wd setup here is a pro/con list of what I know from upgrading.
Pros:
Better torque
Better battery life as each motor works less
Less chance of overheating
Better top speed?
Cons:
Cost
Weight (is it really an issue with the extra power?)
One question I have is what is the feasibility of adding the other set later on or is it just easier to build all at once? Iām not in much of a rush. Also if I were to upgrade later to tb 6380ās would it be ok to put them together or should all 4 motors be the same size?
From the pros list agree with most of those, however the better battery life is probably negligible if you are drawing 400W into one motor or you are drawing 100W each into 4 motors itās the same (for the most part). There is loss as heat in the motor and since the motors would be drawing 1/4 the total power needed there will be some efficiency gain there but I wouldnāt expect it to be huge. Regarding top speed it will also be a negligible change, if a single motor canāt get to full speed because it lacks the torque then you would eliminate that problem but otherwise the speed (velocity) is a product of the motor kv, the voltage, gearing/pulley ratio, and wheel size (more motors is more torque so higher acceleration if thatās what you mean by āspeedā)
For the Cons list I have two opinions to add
Weight is an issue if you plan to use the thing for commuting and/or have to carry it up or down stairs, the things with a single drive and big ass battery are already super heavy so youāre adding to that⦠I wouldnāt consider this an issue for the motors at all but for personal use of the thing as a commuter board it is impractical, if you are just throwing it in a car from the garage and taking it to a trail this probably is a non-issue.
The other con I would add is every component you add is another potential point of failure, more parts == more parts that will eventually fail and more likely any given one fails at any point in time.
Regarding the question of adding on later I donāt see any issue with that if you have the space but will have to add extra parallel connections off the battery main lead so maybe worth having those in place in advance and just tape them off. Regarding mixed motor types for the most part it should be fine if each motor is using current control mode they will all be pushing based on throttle input.
@Papa_Ocean@wafflejock 4WD has 1/2 the total heat losses as 2WD for the same acceleration or constant speed. with 4WD, each motor will be generating 1/4th as much heating compared to 2WD, since there will be half as much motor current for the same performance & heating increases at the square of the current. or if you think of switching from 4WD to 2WD, you have to double the motor current per motor for the same performance, which quadruples the heating per motor, or twice as much heat in total generated overall since thereās half as many motors.
Right loss will be reduced but the actual energy being used to push you up to speed and push air out of the way is the same energy used, losses reduced but watts put into work moving you up to speed and fighting friction is the same.
^bottom left chart shows the same performance, total heat is half in the bottom middle chart (4wd), efficiency is increased in the top left chart (4wd), electrical watts reduced for the same mechanical watts in the upper center chart (4wd), total battery current slightly reduced in the bottom right chart (4wd)
Hmm⦠think we are talking past each other here or at least youāre not seeing what Iām saying⦠The electrical efficiency will be better you will be reducing your losses by going with more motors driving things, Iām not arguing against that⦠Iām saying the majority of the energy goes into the force used to move you and your board and not into heating up your motors. The motors are already in the area of 80% or better in efficiency in converting electrical energy into mechanical power, and any gains you are getting then are in reducing that 10-20% lost as heat, if you cut it in half you have saved 5-10% or get 5-10% better range overall.
