Just plug the battery directly to mains and watch it charge at lightning speed
Pretty sure 10A is the new sweetspot that people want
as long as @Battery_Mooch says it’s ok LOL
120V AC battery here I come.
I would like to see more chargers sleekly built into boards, given at home we can use slower chargers it is when we are out an about that we want superspeed models
ya’ll remember this beauty?
Not sure if this contributes anything but I charge my 13s4p 40T pack at 10A exclusively. But only like once a week since my commute is very short.
Honestly I would want just the opposite, small 2A charger in the enclosure so I can plug it in when I’m visiting someone for that hour or two which Im staying and then superspeed when I’m at home.
Cool idea though
A step up converter in the enclosure and a multi adapter might be enough ![]()
usual laptop charger are available at nearly every place.
Maybe a stupid idea…
I like it.
Maybe 120W available with the laptop brick, about 2.5A charging for a 12S pack after accounting for some power loss through the boost converter in the board?
Guess he never finished that PCB?
Hmm…a small rubber cover lifts up and you can pull out a AC power cord that is wound up like some retractable vacuum cleaner cords. Leads to the charger inside the enclosure.
Takes up a lot of room but would be cool as hell.
Usb-c and buck converter from 24 to the needed voltage?
Might still need to carry a larger than average phone charger though
This is the smallest USB c charger I have seen. 65w is quite slow though.
https://www.amazon.com/FINsix-Smallest-Lightweight-Portable-Integrated/dp/B01KJDN3DI?th=1
There is also this
Add a tiny boost converter
https://www.aliexpress.com/item/1005001787582899.html
might need a little longer for higher plugs
https://www.aliexpress.com/item/1005001796888520.html
oh yeah 5M here but chunky
Why not just use a 10/12s cheap small 2a charger that is always connected to the battery, and mount an input port for 220v in to the charger next to the regular chargeport and then just make a cable from the outlet to the skateboard.
And hopefully somehow stop any current going from battery to the charger to stop it from draining
I did not research, just assumed a step up covert could be smaller.
Lol how did we go from high amp charging to tiny amp charging?
Where ever there is something big, there is something tiny not too far either…
This is my 12s 25amp balance charger set up. I killed my other 1200w power supply recently so I don’t charge at 25amps @12s but I’ll probably get another one considering they are only $10 or so…
No he didn’t.
I’m wondering if he might some day?
Not sure he will.
I heard he came across a shitton of issues that he thought were due to his design but appeared to be mostly generated by crapy chinese power supplies.
Huge step backwards, no more motivation for restarting all the design process…
