1 and 3 are the common ground from the switch and the LED ground.
I put it into the GND on the COMMS port…
I’m kinda thinking its not that hard to put it into the CAN tho… i should probably just follow the picture. It just means if i want to disconnect the switch i need to pull the can cable out as well to depin it. Seems like a fuck around
if u don’t need that uart port, then ya u can use that
just use a small bullet connector there, so u can just unplug if u need to pull whichever one out, save urself of depining the jst plug, then fuck up the little tab later on
don’t count on my vote, we r just assuming all GND is just GND like any other GND, but u know how trampa likes to innovate / redesign things. let us know if u pop anything
@glyphiks you made me go physically dig into an enclosure LOL
So my dual VESC 6 Mk3 is connected like this
The BATT+ of both ESCs are connected together and the BATT- of both ESCs are connected together. It has a loopkey. None of the switch shit is even connected to anything. It works fine.
i don’t supposed u have the wiring diagram, but I will link ur reply in the 1st post to show that it works for option 1 if anyone is looking to go that route
Anyone know if the tb 4.12 vescs have the same dimensions as the flipsky ones? If not where can I find dimensions as they were removed from the tb site after the 6’s came out
