How bad is the bearing seat in the 107s?
Havenât taken the wheels apart in awhile, just remember it wasnât the best. Rode like this for a couple hundred miles no issue, itâs solid with the pulley.
These are the ones with the offset core right? Is that why a longer axle is needed?
The core is offset⌠You need longer axle for the third bearing on the pulley and 3mm spacer. You would need like 40mm+ axle (standard is about 30mm)
Yeah I donât have an extended axle to fit that. Damn that wouldâve been clutch if it was the center set core
Wheels still available
Duro on the vents
Theyâre 77a
Abecs and kneepads still available
Are those pads the sleeve slip on type?
Yeah, they are
Pmâd
Only Abec 107 wheels with 3d servisas 44t pulleys still available
Iâll buy em. Cant figure out how to pm
Hey dude. Youâre probably not the correct level yet and youâll need to read more and post more before you can pm. This is to prevent bot spam. Normally you would just click on @Titoxd1000 name and then hit message.
However in this case n., He might have to start a message with you. Assuming this is still available since itâs 3 months old
I Pmed you
