I’d spend slightly more and get a decent wheel tbh. That valve hole is a chomper without some diy and they look pretty poorly balanced. Also is the 6001 bearing common for mtb? I’m unsure of axle diameters but that’s 28mm OD.
Yes. 12/28 ID/OD is pretty standard, with 9.525mm (Trampa Ultimate) & 10mm (Kaly) I.D. options as well.
Is the standard 9" hub diameter 4.65"?
How do the Innova and Primo Alpha inner tubes of this size compare, in terms of ride feel and durability?
It’s a pretty standard format, is all. Those wheels are just the first I came across. You can find them in 10mm ID bearing variant as well, or just swap out bearings.
some interesting tire choices for reference…
offroad:
The 10" are massive, too big for MTBs. The board gets really heavy.
Those slicks have me
All these muds look cool too
Definitely pushing the boundaries here, however there are a lot of 9" options, and ofc nothing is going to stop me from trying to make the unreasonable work.
Is the hole pattern of the required spokes identical to the regular 8 inch?
Running e-toxx gear drives on 8. Not enough clearance.
The hole pattern of the Megastar is identical.
