He doesn’t know how to be gentle and torques them down too much and breaks them
That too
looks wicked. thanks for the update.
Do you think you’ll be able to do an option for enclosure with no holes?
I don’t really run Battery gauges or power switches.
Fuckin don’t like my post when I accidentally post it.
I liked it more before you finished lol
I’m more concerned of there being a single and double stack version then a weak and strong version.
- sorry I meant cheap and expensive
Most likely, no ABS option, no option without any holes. Sowwiee
@eBoosted got you tho. I can send him the concave. (maybe) lol
That works too. Probably will.
What would be a good method to patch over the hole?
I’m waiting for the 12S8P 21700 enclosure, maybe that enclosure doesn’t need a battery indicator because you shouldn’t need to check.
Any resemblance to existing deck is purely coincidental.
Depends what it’s made out of really
Why wouldn’t you put a battery indicator?
12S8P might be a 12s8p enclosure for a 4WD setup.
It’s just another hole for water to get in your enclosure.
after you ride your board for a while you get a pretty good feel for about where it’s at.
With Bluetooth modules, quality remotes, davga and meter Pros you can check your battery levels on your phone.
And if absolutely necessary you can make a dongle to plug into your charge port to check your battery levels.
The battery gauge on the board is just one more failure point in my mind.
Yesss
I was thinking about how to fit your ESCs into AWD.
@Skunk Depends on how you set it up. It’s almost entirely glass (plastic)* and located on the side and we can always add a rubber seal around the lcd to help with water. Everything around the enclosure will be pretty much waterproof.
Right on.
In a perfect world I’d have an enclosure with absolutely zero holes in it. Less is more.
I would reroute power switch and charge ports somewhere less visible.
@torqueboards will these be sent from the US exclusively or is there anyone in the EU that will stock them?
I would love to get one of these decks but the import tax is killing it for me
