I have found it easiest to mix the JB weld with a drill on some cardboard, use a skewer to spoon it into the hole, use the drill to insert the insert and spin it, further mixing and coating the hole. To remove the screw once inserted, press down or twist to lock the insert and the screw will come out leaving it at the bottom.
