Fixed that for you
Edit : how does Brian even make empty posts under 5char?
Fixed that for you
Haha i know from experience that achieving both power (real gut twisting power) and real range on a off road board is a big pain in the arse! your battery should indeed carry you 80km, this is what i got out of my 55AH battery using dual 80100 motors and 9" tyres. I’m questioning myself if it’s worth to aim for both things in one board though, other than for the glory and conquest! i kinda miss my old 6384’s consuming 18wh/km
This board is purely for long range and dick swinging it’s 4wd on 170kv 6374s and 8inch tires on a 4:1 ratio. Maybe I’ll step up to 80100 if I build a 2wd mtb
Haha I get you mate! Dick swinging is indeed a big part of building overkill boards! your 4wd will have the potential of giving more torque since you got more grip! I went with 2wd and oversized motors instead of 4wd since the pros and cons was in the favour of 2wd for me
Will a 12S4P 40T fit in your century 40 enclosure?
Yes it will. It’s perfect for 40Ts you can even fit a 13s4p
Just did this modular ( @Andy87 style)12s6p with Molicel p42a .
internal resistance measured at 46.2V is 24mOhm .
Thanks Eboosted, sorry to keep bothering you - but do you think two NeoBox HW6s would fit in that enclosure as well? Wondering if height will be too much - Think they read as 22mm tall.
I have not tried that before, but it should
What was this pack intended for?
It’s in my single 6355 drive board
Can I get a link to those nickel strips please
#Aliexpress € 13,86 | 21700 3P titolare e di nichel puro per 21700 batteria 21700 batteria agli ioni di litio supporto cintura nichel puro 21700 nastro nichel
Hmm you might wanna work on the balance wires a bit. Try to have them not overlap each other, you could cut and neaten them
Yes it appears they could use more sauce
