You mean every time you plug it in or turn it on via switch?
every time it’s plugged in. it is the switch.
Ah gotcha. Yeah I’m going to try using those custom QS8s as a loopkey and see how that goes. What is a Jeti?
Jeti doesn’t have as nice a nylon sleve though.
Right but dang 30 ohms, how’s it going to look on your setup as the switch?
i ride an an RC car. so… a lot like the pic above. unplug the batteries. (no loop key)
This hurts my soul Fess
Edit: just realised that’s probably a series connection. Carry on ![]()
Hi again, have these Jeti AS connectors worked out ok while you’ve had them? My FS is holding up fine but it’s on a low voltage board, got a slightly higher one coming up
They are performing perfectly so far! I’m going 22S and we’ll see if they keep on that way.
