140a 21700 cell best in class? JP40
It depends on the manufacturer. The most common are 80% and 60% but I’ve seen 70% too.
I’ve never seen 90% as a 10% loss in capacity is very small and wouldn’t even be noticed by a lot of users in different applications. The manufacturer wouldn’t set an end-of-life spec that high as they could never sell them.
It would also leave the cells as almost-new at the end of their rated life, create huge numbers of cells needing recycling, and force the manufacturer to set very short warranties for their products.
No manufacturer would set 60% as the cutoff if it was dangerous or anywhere near it. That would be corporate suicide.
But any dendrite formation or physical damage that occurs over time can increase the risk of using the cell and both of those occur as the cell is used. I guess the capacity loss can be seen as a time tracker and the manufacturer may set the cutoff as a buffer against the cell’s dendrite formation but the cutoff wouldn’t be anywhere near a danger point. The cutoff is also set as a good indicator of where most people get too frustrated to use the cell anymore.
But both of those risk factors can also significantly increase with almost new cells, depending on how they are used.
There is a huge “second life” market that takes cells that have reached the end of their life and use them in lower power applications like energy storage (“power walls”). This wouldn’t exist if just capacity loss was a safety issue. I’m sure they test the cells for certain obvious warning signs but then they can deliver years of additional service.
We just don’t know…for any of the cells we use. I trust the vendors I buy from but I can’t guarantee that none would ever be tricked by a slimy supplier.
But I haven’t seen anything that indicates there are safety/quality issues and Ampace is a huge, established manufacturer.
Each of us is on our own though. If concerned you can always wait a year or two to see how well the cells are working for others. That leaves the Molicels, which are great performing cells too. Or if you trust EVE, the incredible 40PL.
Thank you that’s great!
I personally would look for the extra 1/8 capacity. At 120+ cells on an esk8 you are going to notice an extra 10km more than you would need huge continuous power. Might the 45D output more Wh than the others at really high load even if it sags more?
I have the cells ready for be purchase and beating any pricing. Full box 130 pcs has a special offer. Shipping from Florida. Check my store DIY500AMP dot COM
No thank you
Blessings !!
I glad you like my video and testing.
