An important thing to note is the wheel size I’m working with which is 90mm. A key disclaimer is that there is no practical purpose for my system that I’m making save that gear drives are cool and I could put this together for less then $100 which is important for someone without disposable income for esk8.
As you can probably tell the motor would be way too close to the hanger and therefore I produced the current version of this system. While nowhere near complete this version utilizes gears from vexrobotics.com for maximum cheapness and I’m still working on the case.
Another advantage of these vex gears is that the one I’m currently using has slots that can easily be used for a push fit adapter for the wheels that could be made for ABEC or kegel wheels. To keep the driven gear centered there is a lip in the adapter to hold a bearing to ride on the axle.
Ones I dont have at the moment. Trying to get the whole system onto a 34mm shaft is either not possible or far more effort then I care to invest. Ill try modeling the system around @Boardnamics or @torqueboards hangers. That might produce a better result.
As somone just getting into the hobby and building my first board, id love a geardrive but they are so expensive. This is exactly what I’m after. Noob question - will wheels less the 90mm work with this? (im thinking 85mm)
Esk8’s been on the back burner due to a couple of things(mainly the presence of snow) but I’ve been slowly been making iterations and minor improvements as I go along. As of now Axle to motor distance is 76mm and as too minimum wheel size I think you could barely squeeze in a 85mm but it could be doable with some tweaking. As to file sharing I’d like to have an actual working version before I consider doing an “alpha” or so.
Gear drive assemblies really aren’t that much more expensive. Every one I’ve seen is premium gear. You can’t compare that to $15 mounts and $25 pulleys for a belt setup. Make the comparison to a premium set of push fit pulleys and brackets and the price gap becomes a lot smaller
I have a full set of parts ready to go but tragedy struck in the form of the USPS damaging my 3D printer. I’m in the process of fixing it but in the meantime I have all the gears/bearings and shafts ready to go. So once my printer is up and going again I will have the first full prototype.
