MBS Core 94 & MBS Colt 90X
MBS Core 94
Price: $250
MBS Core 94 has been drilled out to install t-nuts that hold the pelican case.
The ESC case is a simple case I created to fit most ESC’s and should get the job done.
The board comes with IDEATB Motor mounts and a Back riser to help angle the mounts higher from the ground. Tires are used but not smoothed out and tubes are working in all tires.
MBS Colt 90X
Price $150 OBO
This MBS Colt was sanded then dyed and seal coated.
I was not fond of the consolation artwork so I had to customize with rite dye and sealer.
The deck has holes and t-nuts placed for mounting a pelican case for your battery.
The ATS trucks are NEW never ridden just installed.
The ESC case is something I printed up very quick to get the job done.
There are also Risers to help angle the back truck for IDEATB mounts not included on this deck.
