(WTS) [US] Caliber II Trucks
Parts for sale. Some used and many unused. Willing to ship to US. Buyer pays shipping.
[SOLD] FOCBOX v1.6 - $110 - Used - XT90 and 5.5mm bullet connectors
[SOLD] Miami 12s3p - $200 - Unused - XT60 connector
[SOLD] 3A fast charger - $15
Measurements are (5 3/8" x 13 1/4" x 1 1/4") (137mm x 337mm x 32mm)
[SOLD] FLIPSKY Smart Antispark Switch (Pre-Redesign) - $30 - Unused
[SOLD] Turnigy SK8 6374 192kv - $80 - Unused
[SOLD] HM-10 Bluetooth Module - $8 - Unused
[SOLD] Dual Idler Motor Mount (Caliber compatible) - $25 - Unused
[SOLD] Set of ABEC Clone wheels with ABEC-7 bearings - $15 - Used
Pair of Caliber II 184mm Trucks - $20 - Used
I’ll take both of the 330 belts!
Do we know what cells are in the battery?
It’s a MEB pack, it’s 30Qs.
Das a good deal then. :+1:
Dimensions of the Battery?
Also what is the purchase date of the antispark?
It went through a redesign recently.
Shit I want that battery
But… must hold out… For 30t ;_;
@covenant Can you give us a purchase/manufacturing date on that pack please?
The antispark switch was purchased before the redesign and posting the dimensions of the battery tomorrow forgot to measure it. From loose memory it’s 13"x6"x1.5"
I’m not sure how to figure that out. But I can tell you that I bought it like 8-10 months ago and have been topping it off every few months since then
Just a note. That battery is “thick” but short because the BMS is on top of the cells, surrounded by foam and a plastics shell to make that shape.
Good battery. Still using mine but I had it “flattened” out
Who flatened it out for you? Or could you easily just cut it pull it forward and re plastic it?
I had @Chibatterysystems do it in the US. But realistically you can do it if you’re not chickenshit like me. Just cut the wrap, remove the plastic rectangle and foam. Pull the BMS and cut the BMS balance wires taking note of which is which and make sure none of them touch each other. Strip then extend said balance wires, add heat shrink and place the BMS at the end of the pack and reheatshrink the whole thing.
The 12+1? balance wires length prevents it from being a simple repositioning
Unfortunately, I think it’s too big for my purposes :(.
This is what the 12s3p battery looks like after flatten it out. I have it in a hummie deck and still got plenty of wasted space
Too wide, I was thinking of replacing the 10s4p NCR18650BD pack in my electric scooter, the battery compartment is only 5" wide.
thanks for the info though!
Measurements of the battery posted, hope it helps.
I just wanted to say thank you for the HD photos
How is this FocBox not gone yet?
Interested in BT module, wheels and mount.
Interested in BT module too
