Looking to get a pair of the new BN long motor mounts, just need to fund that endeavor and have a little cash spare for when shit goes wrong, I don’t skate as much as I used to so I don’t need all these extra toys, if you have questions lemme know and I will give you as much info as possible
I can ship to Canada if you can cover the shipping, the complete might be messy to do though
Prices are SHIPPED in the US!
Single drive complete
This board costs about $800 to make so this is a SIGNIFICANT saving
Parts have from 30 to 300 miles on them, battery has less than 10 cycles. Board weights 13lbs and gets 12mi of range on flat ground with a 125lbs rider, top speed of 18mph with a 14T pulley and I have 15/16/18T pulleys for sale
10s charger included
Part
Name
Motor
TorqueBoards 6355 motor
Deck
“Skate Shread 36"” x 9.5"" bamboo blank deck with black griptape"
ESC
Flipsky 4.12 ESC
Trucks
158mm 50° white/gold Caliber trucks
Cells
Molicel P42A
Remote
Flipsky VX1
Wheels
76mm Ahmyo Akasha cut wheels
Antispark
Flipsky 280A antispark
Wheel pulley
Janux 34T kegel core bolt on pulley
Enclosure
Meepo battery case for V3
Bearings
Zealous steel bearings
BMS
DALY 10s 15a BMS
Motor mount
Build Kit Boards single piece Caliber motor mount
Motor pulley
TorqueBoards 14T steel pulley
Bluetooth
Enertion HM-10 bluetooth
Deck protectors
Dickyho X deck protectors
Belt
250mm HTD5m 12mm belt
TB 44T kegel pulleys
2x used TorqueBoards 44T bolt on kegel pulleys with black alloy steel bolts
Flipsky dual 6.6+
Used Flipsky dual 6.6+ with button, XT90, 5.5mm bullets
Daly 18s BMS
New Daly 18s li-ion BMS with balance leads
Misc electronics
2x new 10s BMS
New 60v to 12v 20A step down
[SOLD] Used Raptor motor adapter
3x dead TorqueBoards 4.12 ESCs
Haggy Senor Pepe wheels with Exway pulleys
Haggy Senor Pepe wheels, almost no use. No bearings, 36T press fit pulleys (not the ones pictured)
Racerstar 140kv 5065 motors
2 brand new and 1 used (119kv effective in FOC), might have 15T d-bore pulleys to match but I’ll have to check
Take the mini trigger cause I’m cheap
b264
November 24, 2020, 5:38am
#3
Second in line for this if the sale falls through
I’ll let it go for 18bucks
Sold what do I care. It’s only money
What happened while I was away…? Are you still getting the remote?
b264
November 24, 2020, 6:21am
#10
We’re bumping your thread for maximum visibility
Your service is much appreciated!
Bump. bump bump. bump. Bump bump thas the sound of my fitys hittin in my trunk
frame
November 24, 2020, 6:24am
#13
b264:
maximum visibility
can confirm, I clicked this thread more times than I should, I got no money to spend
Whatcha got your eyes on?
You always got credit at uncle Tetras
frame
November 24, 2020, 6:29am
#16
nothing specific, I just keep on browsing parts market when I have no money
Lmao that’s such a mood, on the days or weeks I’m ‘not active’ I always watch the for sale threads for toys I want
frame
November 24, 2020, 6:41am
#18
i basically have the parts market page as shortcut instead of the main page, this is where i browse most often.
Haha same here, I even black listed all the other categories on the old forum so I only see parts market stuff
Wheels and motors up for sale, lots of spicy red here
Haggy Senor Pepe wheels, almost no use. No bearings, 36T press fit pulleys (not the ones pictured) - $72
Racerstar 140kv 5065 motors, 2 brand new and 1 used (119kv effective in FOC), might have 15T d-bore pulleys to match but I’ll have to check - $157
