Psychotiller V1 HeXL split angle liquid TKP precision CNC trucks with 35/45 degree baseplates and 260 mm hangars, pre mounted are Boardnamics 90mm center adjustable angle idler style motor mounts with 2 part clamps for the HeXL hangars and double bearing adjustable tension idlers. Comes as is, a little cosmetic damage but all the parts are straight and in grest condition still. They ride super clean and you can run dual 6396 motors on them, carvy at low speed and stable at high speeds, just not my style anymore
Asking $169 (free shipping) plus fees. Shipping from Newark, Delaware, 19711. Product weight is 1.510 kg
Thanks! Originally it had a blue wrap and ugly sticker, I re wrapped so I could make it fit in the enclosure, there used to be a foam block on both ends I removed
