600€ for my friend’s board
He works far from where he lives so he doesn’t have a need for it unfortunately. Been ridden a few times, hence the scratches on the bottom.
How does it ride:
With TKP trucks and a very low standing platform, this board is a perfect carving and cruising machine for those who like to keep it below 45km/h. Going faster takes some real skill, and just isn’t what this board is designed for.
Board is in working condition, and has the enclosure sealed with butyl tape to be as water-resistant as possible Expected range is ~30km I’d say
Parts:
- Hummie deck with custom artwork by Sender (fine frit)
- BigBen single stack fiberglass enclosure
- 10s4p 30Q battery from electricboardsolutions. Has a bypassed BMS, I’m guessing it has around 50 cycles on it.
- Surf Rodz 177mm TKP trucks with Boardnamics 10-8mm step-down axles
- IDEA motor mounts
- 3DServisas 48T kegel pulleys
- TorqueBoards 110mm 78A wheels (the ones that never chunk
- 2x 6355 170kv Maytech motors
- 2x Cheap Focer 2 ESCs (Vesc 6 based)
- Flipsky anti-spark switch (the one that doesn’t fail eventually) – has roll to start
- Flipsky VX1 remote
- 5A charger
Build thread:
The Domino’s Board | Senderized Hummie deck | “Budget build”
More images:
Should be able to ship the board within the EU. For international interested buyers I could ship without the battery. Parting out is also possible, since there are a fair bit of high-value parts on this bad-boy
