That’s good. Make sure you don’t prematurely close the dispute, because usually you aren’t able to re-open it. And they will probably try to get you to close it before doing anything, to get rid of your leverage.
Trust me, I thought of that haha. I don’t trust this company at all.
I am buying VESC 6.6 from a member here now, so I might just get my money back
I had issues with my 6.6 communicating across CANBUS. Wouldn’t update both side firmwares even with “upload all” and would only spin up one motor at a time.
If flipsky just got their shit together, they could have an awesome product
what FW Version you are using?
Can’t update that’s a corrupt/missing bootloader that’s a flipsky surprise feature 50% of My flipshite ESC have it. You need a st=link V2 to fix update it. Motors spinning up differently unlikely to be a ESC issue too. Belt too tight or bad detection or issue with hall sensor.
was 5.0, 5.1
st=link v2?
The motors would spin just fine depending on which side of ESC i connected to. Either one would spin its own side
try an older version of the fw, just to check, had a similiar issue some days ago
Why not just update and program both individually? That’s how I did it with my 6.6dual. just make sure one is programmed as a master and the other as a slave (id 1 and 0)
Also…kinda obvious but still…there’s a can forward option
I tried all of that haha
Enlighten me haha
@ethana4
When an esc doesn’t wanna bootload or update, it’s sometimes sign of a corrupted chip. An stlink allows to connect directly to the chip to hard install a new bootloader into it. Which can make you go from
“Why the fuck won’t you work you piece of shit?”
To
“You’re working like magic, I love you”
Here’s the controller required to hard program the chips
Happen often enough that it should be in everyone’s tool box?
For me yeah. I bought 2 flipsky dual 6.6 escs. Both got corrupted
Yes, and since it’s cheap as shit, no reason not to have it.
What’s the process
That’s a whole other story I’d recommend researching in here and a bit in the old forum. Everything is there, and since it was explained to me, I’m not entirely qualified to assist you in not screwing it up
How long did it take you?
And if you link me a specific process that would be awesome
