any of them. ( any that work via PPM or VESC Uart. )
I need a ppm harness that I can use with Unity. Suggestions?
Just ordered this just for the ppm harness. Think it will work, although I cant remember what each color wire signifies. If I have to I can rearrange the cables in the JST connector
https://www.amazon.com/gp/product/B00WJJG8YW/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Hey do you think you could check what jst connector I need for PPM on unity ?
Sorry, I don’t have a board open to check that.
All good. I’ll get it figured out. Thanks though
It’ll take forever to arrive. Like 2 months.
Bough it from someone on here. Should be here tomorrow
Good. You’re probably better off getting it from somebody on the forum. Probably tested too.
Agreed. As far as I know this one worked perfectly.
Alright so I have a power switch coming. Does it make any sense to use it with my setup. Me batteries directly to ESC. No.BMS. I unplug batteries to turn board off normally
Have you accepted Skatan as your lord and savior and confessed your undying devotion to his dark lordyness? That’s the next thing you should probably do after initial motor setup.
Oh I did that shortly after starting my DIY mountainboard build hahaha
