Also, do I have to have a unity switch? Mine will be connected directly to my batteries. I turn the board on and off by unplugging them
You can short the unity switch so it will turn on with your battery. I havenāt done this so I donāt remember which pins need to be shorted off the top of my head. Iām sure you can find it if you search āunity switch short pinsā
And could you send pic of switch plug?
alright, so I need to take a 5 pin jst and do what the picture shows
Bingo
Is it regular JST, or a subcategory size
Iāll go measure for you, please hold.
2 mm pin spacing so Jst PH
I donāt have the original bluetooth that it come with, just the Metr module. So that means I canāt use focbox UI?
Not sure on that one, I havenāt used the metr module.
Maybe @longhairedboy knows and can chime in here haha.
I also need to know if the hall sensors for my turnigy sk8 6374 motors will plug directly into ESC or if I need adapters
I think you can. but Iām guessing. I asked for confirmation in the metr thread.
I know you can setup your board using the metr app. it has support for unity. I did it in a pinch from ios version.
focbox ui from a mac (compiled) can connect to and configure a unity using a metr module. and I think itās the same QT codebase to used to make the android app so I think it should work unity app to metr module to unity.
Appreciate you checking.
He just said he asked for you in the thread he linked
Sweet. What else do I need to know? This is a whole different ballgame than the flipsky 6.6 dual, but I donāt want to support that company at all. However, I do still have a flipsky vx1 remote I think Iād like to use with this ESC if I can. Need to know if itās compatible and how to connect it
Also what fuse did you use as a replacement for battery gauge?
No need to worry about that unless itās blown right? Ask me if it ever happens and Iāll look it up.
Appreciate it. Iāll have the 6.6 dual as backup too. I need to figure out what remotes I can use with the unity as well.
