Wtb focbox unity
As title suggests, pm me if you have one.
Thanks
everyone wanting one, good luck tho.
A man can dream…
im holding on to mine for dear life.
Isn’t the new dual fsesc 6.6+ better than the Unity if you dont use the UI and other crap? Or does that only apply to the bigger motored boards?
i think the unity is just easier to use and UI is just better. tbh, i’d just get two vesc if you’re not doing a huge fancy build.
I need the focbox unity for my build as space will be so tight. Lacroix deck and 12s6p 30q
o. nvm me.
You know Jed Boards have pickle rick mode right? Says that in your bio
Very strange
The latest Dual Flipsky 6.6 is very small! I’m probably going to pick up a second one to make my board 4WD if I dont have any issues with this one.
What spec board are you planning to run it with?
I would be running dual 6380 at 12 S not sure if it could handle it.
either you are a giant with enormous hands or it’s very very small.
Having a hard time deciding :joy:
Yeah, maybe those power leads are like 2/0 battery cable. Or the unit really is that small
My build is just now coming together. I have another set of motors, pulleys and motor mounts so with an additional controller this board can be 4WD. I’m more worried that my battery pack, although massive in capacity really shouldn’t draw at greater than 60A-70A continuous.
Landyachtz Evo 40 Falcon
Eboosted Enclosure: https://www.eboardsperu.com/product/landyachtz-evo-39″-ds-v2-4wd-applications/
12S6P(7P?) Samsung 21700 48G 4.8Ah cells
Torqueboard 218 trucks
Torqueboard 110mm wheels
3DServisas 36T Pulleys https://shop.3dservisas.eu/
1" risers
Maytech 6369 200kv motors https://michobby.com/collections/motors-hall-sensor-and-sensorless/products/maytech-6365-200kv-brushless-sensor-motor-for-electric-skateboards-e-bike
Whooshboards motor mounts https://whooshboards.com/
Flipsky Dual FSESC6.6 Plus https://flipsky.net/collections/electronic-products/products/dual-fsesc6-6-plus-based-on-vesc6
Flipsky VX1 Remote https://flipsky.net/collections/accessories/products/flipsky-remote-vx1
300A Bluetooth BMS https://www.aliexpress.com/item/32827394534.html?spm=a2g0s.9042311.0.0.27424c4d7mrl4n
Best to make a build thread and post there.
Sell to me
Afaik the flipsky 6 variants have always been solid
