I need a small double stack enclosure for my Tayto. Preferably something below $100. Doesn’t need to be anything special, just a box will do fine. PM me if you’ve got something that might work.
Something like a psycho flagship v2, tayto eboosted enclosure (a bit expensive) or anything that will fit a double stack battery.
Mine cracked on it’s last ride. It cracked were I drilled through it, I mounted in the enclosure so that may be why. Just something to be aware of. Also I had to shave a bit of the enclosure to get raptor trucks to fit.
I built in one of his enclosures before np. I drilled though the deck and used skate hardware than used silicon to waterproof it. It was a beast. Think it was a split low or something.
