I don’t have the deck and don’t know if it’s an easy one to get over here?
Need the deck and demand to get one.
Your battery too big for the hummie?
Do you have a picture of the nearly finished item?
Not sure what you mean
Pic of the finished battery
Also it’s everything is to big for the hummie
I would have to route around 5cm on the ends and 1cm on the sides
Yea I have a new evo40+eboosted DS enclosure for it.
That seems like a lot to cut out from an important part of the deck…
I’m making a 12a6p P42 on a Hummie 4wd but have planned my battery and build around the deck. DIY segmented enclosure.
Been said many times by others, but deck and enclosure first…
Yep tried to
Issue is first battery build ever so took up more space cause I used extra fishpaper and nickel and etc…
What total length do you need?
Evo would probably give you something like 620mm?
Yep 620mm is fine
Need like an extra 5-10cm over the hummie
With width an extra 2cm
Hummie gives you 585mm? So you need 635mm-685mm? Measure twice, cut once.
Yep gonna measure tomorrow morning
The eboosted enclosure def fits though as I was speaking to eboosted and we made sure so
Thanks a lot
Eitherway waiting for @mackann to reply
Pls check your IG DMs I replied to you on January 8th
Perhaps update your post w the correct info?
Ah so sorry just checked today and didn’t see
Once again so sorry and will update
Sorry yeah for some reason my account doesn’t seem to log in anymore and I forgot my username
I only created an account to contact you
And the forgot my password doesn’t seem to be working
Why don’t you go haero, Ben is making enclosures I think
Making a speed board so looking for a street deck
How fast you planning on going? I think aerodynamics is not an issue unless you want to go at insane record breaking speeds
No but stability is which many mtb decks don’t have so well
Looking towards the 50mph mark as my goal
50 is pretty high, my haero is 50 weighted so I’ll let you know how I get on with stability when I get my bindings.
My Trampa hits 35 and is stable even with 9” tyres, I guess there’s more confidence in stiff low riders
Yeah exactly that
For the moment would prefer a street board
For some reason all my Instagram accounts keep getting shut down so trying to contact @jamie has been a nightmare
Have you considered not wearing bindings when going really fast?
If the unfortunate does happen at those sorts of speeds it’s nicer not to be attached to the 20 kilos or so…
