Hello,
I just got done with my build for the most part. The only thing missing is proper rims to mount 8inch AT tires on.
The front axle wheel mount of the Flipsky trucks only measure about 46mm including screw thread. Does anyone know which rims will fit on it besides the rims offered by Flipsky?
Friendly greetings
Sebastian
Most rims will fit as long as you have the right bearings
Unfortunately these Syl 08 rims i have don’t fit so it would be great if there were some visual cues or measurements to look for instead of trial and error. They do fit on the rear axle but for whatever reason the mounta on the front truck are shorter and don’t fit these rims .
You will need 10mm bearings for these trucks.
I ride them with evolve rims but I’m not sure if they fit 8" tires
I went with the metro board at hubs and 10mm shaft bearings for these trucks
I used the same trucks. But, they have since changed design, to accommodate more wheels. I had to machine truck flanges back to fit. Still using some washers. Also had to machine, to have pulley teeth in line with motor pulley. Wouldnt want to do that again.
