Where to buy axels for surf rodz
Where can I buy axels for surf rodz? Not shoulder bolts but axels…
@Boardnamics @akhlut
That are 60mm and under lol @ZachTetra
Surf rodz, mcmastercarr
Oops you said not shoulder bolts
lol that’s something you have to specify
They have to be custom made if theyre not shoulder bolts
Well that blows d!ck @Boardnamics
If you have a lathe with a thread cutter, or an angle grinder and a die you can make an axle from a shoulder bolt…but if they are case hardened you are boned
Get some 10mm threaded rod and fkn send it. If you’re lucky, you can find some in double sided threaded ends that might actually work.
jesus crazy method but might be mad enough…
I just machined some axels for my custom trucks. I used 17-4 ph stainless steel, Preheated and have material certifications. I’d be willing to make some more If interested
Why do shoulder bolts not work? They are the same as I’ve understood it?
I prefer an axel with a shoulder that tightens perfectly to the hanger
I’d download some pics, but can’t get it to work
Haven’t added the wrench flats yet.
:heart_eyes::heart_eyes::heart_eyes::heart_eyes::heart_eyes:
Very nice :ok_hand:
Those look hella nice, if you happen to make some spares I take them. :grinning_face_with_smiling_eyes:
I would like 2 sets at least!
Overall they work the same but with the shoulder bolt you have the take the hole bolt off and take off the thread lock. With the axels you can put stronger thread lock on the inside thread and the just use a nylon nut on the outer threads. Plus most of the axels made use 8mm bearing and not the 10 mm that are required by surfrodz
