Last night I was riding and hit a decent sized pot hole and one of my motors is now making a clicking noise. I took apart the gear drive and made sure the gears are sound and mounted properly. Nothing appears to be rubbing. I can’t reproduce the sound by manually spinning the wheel/motor.
Yah would swap the bearings out with another wheel see if that’s it can also just run the motor without the wheel to see if it’s in the motor or the wheel.
Ok I finally got around to tearing this thing apart and before I take the motor off and take it apart, does this sound like a broken magnet? I would have figured the knocking would persist even if there was no load on the motor.
It cant bee a magnet when the clicking sound appears again when the wheel does one full rotation. The motor does 2 or more rotations while wheel is doing it’s one full rotation. Can’t explain it nicely lol but I guess some of you understand what I mean.
Actually what it was was that one of the teeth on the wheel gear got slightly deformed. So on every revolution of the wheel the teeth of the gears would knock into each other. I replaced the drive gear and that resolved things.
