Hi Everyone, my go foc dv6 just died after maybe a month or less Had been going Great but today a little into the ride it felt like one of my motors was going out of sink with the other one random crabbing on the back end a bit after coming off the power. then when nearly back home it is suddenly riding great againā¦ i go for a few hard bursts then when braking it died sounded like it a small blast sound like bust into flames. after taking it apart. looks like a senser port caught fire ? what happened here ?
Thanks Robbie
think u need to open it up for a better look inside
The sensor port was likely a casualty of the fire and not the cause. Iād lean towards one of the capacitors popping given the damage and your mention of āa small blast soundā Back in the days of crt computer screens I witnessed a few caps turned flamethrower
From the direction of the scorching Iām going with this capacitor here.
Now what caused that to become a fire breather
getting harder and harder to find reliable VESCs
Definitely looks like something in the power stage decided it didnāt want to live anymore. Kind of hard to tell exactly what with the low photo resolution and soot.
Itās possible one of the caps moved under vibration and wore through the insulation, or maybe there was a loose fragment of something conductive that somehow ended up inside the case and caused a short.
Itās also possible that it was an undetectable internal defect of some component, and it finally had had enough.
It seems they All have QC issues cheap or expensive
Itās the nature of electrical components, probably not a fault with the vesc qc process in this case. Contact MakerXfor a replacement
Operating caps anywhere near their rated voltage is a great way to reduce their life, especially with the millions of voltage spikes these caps are being asked to handle. Adding on to that is the heating caused by the current ārippleā that causes current to rush in/out the cap during operation.
If the caps canāt handle that ripple current heating or they are experiencing voltage spikes at or above 63V then they can fail.
I still believe foc mode is hard for newer vescās , or maybe i am just lucky with my twin vesc 4.10 in bldc mode and i run them at 12s /80-90A each since 3 year in aluminum enclosure .
but what about the hfi vesc from trampa ? maybe lot more reliable
Yeah, itās really hard to narrow down a failure like this when the resultant skidmark covers half the top surface of the PCB and a good bit of the bottom too. The good old āfollow the smoke trailā method has its limits.
This topic is temporarily closed for at least 4 hours due to a large number of community flags.
