Just was about to comment on the other thread if those you offer there have really just 50km on them than I understand why you don’t like the sound mine look better after 500+km
can you program an arduino?
if so – use can-bus library parse out the params you care about and map() them to a range for the tone() function.
if you want it to sound like an engine instead of a 8-bit video game you’ll either need to find/buy/write your own sound function or a discrete module – I would recommend circuit-bending a kid’s toy car.
If you don’t know how to program – FYI: you aren’t asking for help, you are asking someone else to do almost all the work for you
sorry for the snark about programming!-- I’m sure you’ve seen the number of ‘just some help’ requests that really mean do all the work.
my suggestion about finding a kid’s toy that makes approximate noises is what several artists friends do for projects. using an arduino to rapidly trigger the sounds, and screwing around with the capacitors, resistors and input voltage to change it to what they like. It has the advantage of already being self contained – allowing the actual programming to be limited in scope to triggering in response to events.
the FFT library can be used as well to strip a complex signal down to something manageable.or conversely build a more complex sine wave for play –
the processing speed of the arduino makes complex responsive sounds or events a real headache. I built a controller for animated christmas lights and the first dozen revisions would lag so much it didn’t look like the lights were in time with the music at all
