Is it by any chance a vesc6+ that was on sale as refurbished for £120 like 1 month ago?
Nope, I bought it for 160
Deffinelty drown it in lagunitas first, then try motor detection while the motor is in small pool of lagunitas…ok i leave now
Trampa website? I got 2 6+ that shit the bed the moment i tried to ride them.
Meanwhile maker-x dual hit 500km around this week without any problems.
I sent the vescs for repair on 12 may and it’s radio silence from trampa since then
Costco typically sells 99% for dirt cheap. It really doesn’t make sense to buy it from anywhere else.
Getting flashbacks to that thread about dunking unities in rust remover
Ok so when I do motor detection, nothing happens and I get bad detection recieved. This is with the “new” vesc tool @Trampa
I don’t think it’s FOD, Lol, cleaned it up and this shit lol
the default detection current in vesc-tool is now 20amps??
or were you increasing the i value because detection was failing at lower current levels?
It automatically puts 20a lol
Shouldn’t it be only 5a?
for the motor sizes we use, that sounds more reasonable to me. but what do i know?
You should use the wizard, since there you can select a motor size and then the detections amps are matched to the approximate stator size.
Dude, I’ve done that, I did the detection and the resistance is absurd.
Then there is a HW issue.
So what am I supposed to do now, I asked for help lol
It needs to be fixed by some one doing VESC repairs.
You could take the PCB out of the housing and inspect it visually.
Sometimes it is possible to see physical damage.
